Salta al contenuto principale
Samsung PL200 Battery Replacement
  1. Samsung PL200 Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung PL200 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
  2. Samsung PL200 Battery Replacement: passo 2, immagine 1 di 3 Samsung PL200 Battery Replacement: passo 2, immagine 2 di 3 Samsung PL200 Battery Replacement: passo 2, immagine 3 di 3
    • Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
    • This will release the spring loaded battery.
    • Use your fingers to remove the old battery.
  3. Samsung PL200 Battery Replacement: passo 3, immagine 1 di 3 Samsung PL200 Battery Replacement: passo 3, immagine 2 di 3 Samsung PL200 Battery Replacement: passo 3, immagine 3 di 3
    • Insert the new battery into the battery slot.
    • Push it down with your finger until the blue release switch re-engages over top of the battery.
    • Close the battery/SD card compartment.
Conclusione
After replacing the battery, be sure to connect your charger cable and charge the new battery fully before using it.
Clemson, Team 15-7, Shirley Winter 2015 Membro di Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Membri
9 Guide realizzate
2 Commenti
Is the battery dead? Can Samsung indicate wher new batteries are sold? Camera retailers are rare, these days
Reginald Parker - Replica
No-one can find a contact address for Samsung spares. New smartphones, no problem! Thank you for trying. I just have to keep looking! Reg
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,098
