Salta al contenuto principale
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
Minje Sa
Minje Sa e 3 altri collaboratori
Ultimo aggiornamento il November 17, 2022
15 minuti
Facile
Introduzione
Vai al passo 1
The hard drive and SSD of your computer is the main data storage unit of your device. Overtime the storage unit is susceptible to stop working as originally intended. In many cases, the data in the hard drive/SSD may become corrupted. If you’re experiencing any problems with loading files in your computer, consider replacing the hard drive/SSD.
This is the Hard Drive and SSD replacement guide for Samsung Notebook 7 Spin NP740U3MK01US. If you suspect that your hard drive is failing or want faster processing speed and capacity upgrades, please follow this guide.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Mostra di più…
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 2, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 3, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 4, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 5, immagine 1 di 3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 5, immagine 2 di 3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 5, immagine 3 di 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: passo 6, immagine 1 di 1
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 8, immagine 1 di 1
    • Pull the hard drive away from the cradle and remove it from the device.
Conclusione
2 Commenti
Would you point out where the SSD slot would be?
aroyphillips - Replica
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,613
