Salta al contenuto principale
Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement
Cosa ti serve
  1. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement, Bottom Case: passo 1, immagine 1 di 1
    • Flip the laptop over to access the bottom case.
    • Using a Phillips #000 screwdriver, remove the ten 6mm screws that secure the bottom case.
  2. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 2, immagine 1 di 2 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 2, immagine 2 di 2
    • Pry along the seam using an iFixit opening tool.
    • Lift off the bottom case.
  3. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement, Battery: passo 3, immagine 1 di 1
    • Locate the battery towards the bottom left corner of the laptop.
  4. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 4, immagine 1 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 4, immagine 2 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 4, immagine 3 di 3
    • Using a spudger or iFixit opening tool, loosen the bundled power cable from its connector on the motherboard.
    • Disconnect the bundled cable connector.
  5. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 5, immagine 1 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 5, immagine 2 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 5, immagine 3 di 3
    • Using the Phillips #000 screwdriver, remove the three 5 mm screws holding the battery in place.
    • The screws are towards three corners of the battery, although there is an extra screw mount on the battery that is not used in this model of laptop.
  6. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 6, immagine 1 di 2 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 6, immagine 2 di 2
    • There is a "lip" in the bottom right corner of the battery mount.
    • Gently grip the battery from the sides, lift up and and to the left to remove the battery from its place.
  7. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement, Touchpad Button Board: passo 7, immagine 1 di 2 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement, Touchpad Button Board: passo 7, immagine 2 di 2
    • Using a spudger or iFixit opening tool, remove the clip holding the ribbon cable in place on the motherboard.
    • The small plastic clip is important for the re-installation process, so be sure to place it in a secure location.
  8. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 8, immagine 1 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 8, immagine 2 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 8, immagine 3 di 3
    • Using a spudger or iFixit opening tool, carefully peel back the two layers of security tape covering the second cable mount.
    • You may fold back the tape and let it rest gently, to be able to re-seal it after replacement.
  9. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 9, immagine 1 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 9, immagine 2 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 9, immagine 3 di 3
    • Using your Phillips #000 screwdriver, remove the three 3 mm screws holding the board in place.
    • Locate and peel up the yellow tape from the third (back) ribbon cable.
    • Using the spudger, pry the black plastic clip that secures the ribbon cable and remove the ribbon cable.
  10. Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 10, immagine 1 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 10, immagine 2 di 3 Samsung Notebook 5 NP530E5M Touchpad Button Board Replacement: passo 10, immagine 3 di 3
    • You may now use a spudger or iFixit opening tool to gently lift the board from its seat.
    • Remove the faulty board and dispose of it responsibly.
    • Now following the steps in reverse, you will be able to install the new touchpad button board.
Conclusione
Lucas Gil
Membro da: 09/07/23
690 Reputazione
5 Guide realizzate
Gateway, Team 1-1, Gonzalez Fall 2023 Membro di Gateway, Team 1-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 88
