Salta al contenuto principale
Samsung Notebook 5 NP530E5M RAM Replacement
Cosa ti serve
  1. Samsung Notebook 5 NP530E5M RAM Replacement, RAM: passo 1, immagine 1 di 2 Samsung Notebook 5 NP530E5M RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the single 6.5 mm screw that secures the plastic door labeled "Memory" to the bottom case.
    • Set the screw to the side in a secure location.
  2. Samsung Notebook 5 NP530E5M RAM Replacement: passo 2, immagine 1 di 1
    • Insert a spudger or opening pick under the door, and pry it open.
  3. Samsung Notebook 5 NP530E5M RAM Replacement: passo 3, immagine 1 di 1
    • Use a pry tool to disengage the pressure clamps holding both sides of the RAM chip.
    • Open both sides simultaneously to release the RAM module.
    • Once released, the existing RAM will pop upward.
  4. Samsung Notebook 5 NP530E5M RAM Replacement: passo 4, immagine 1 di 1
    • Gripping from the sides, gently pull the RAM from its seat.
    • Be careful not to break or bend the leads on the RAM, as this would render the unit useless.
  5. Samsung Notebook 5 NP530E5M RAM Replacement: passo 5, immagine 1 di 2 Samsung Notebook 5 NP530E5M RAM Replacement: passo 5, immagine 2 di 2
    • Align the new unit with the RAM slot, and insert the RAM stick at a slight angle, it will rest loosely in its seat.
    • Lightly press down on the RAM until you hear a "snap". This means that the latches have clasped shut, securing the RAM stick.
    • There are two RAM slots in the Samsung Notebook 5 NP530E5M. We recommend that you install the first RAM in the bottom slot, in case you decide to add more RAM later, you wont need to worry about removing your first stick.
    • Replace the memory door and secure the screw. Tightening the screw, but be careful not to apply to much torque, "stripping" the screw, rendering it useless.
Conclusione
Lucas Gil
Membro da: 09/07/23
690 Reputazione
5 Guide realizzate
Gateway, Team 1-1, Gonzalez Fall 2023 Membro di Gateway, Team 1-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23S1G1
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 410
