Salta al contenuto principale
Samsung NX2000 Lens Assembly Replacement
Cosa ti serve
  1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: passo 1, immagine 1 di 2 Samsung NX2000 Lens Assembly Replacement, Lens Assembly: passo 1, immagine 2 di 2
    • Begin by pressing the lens lock button to the right of the lens.
    • Release the button and turn the lens in a clockwise motion until you have removed the lens.
  2. Samsung NX2000 Lens Assembly Replacement: passo 2, immagine 1 di 3 Samsung NX2000 Lens Assembly Replacement: passo 2, immagine 2 di 3 Samsung NX2000 Lens Assembly Replacement: passo 2, immagine 3 di 3
    • Make sure your camera is turned off and flip your device upside down.
    • Slide the battery switch to the left and open the battery compartment.
    • Push the blue button up inside the battery compartment and remove the battery.
  3. Samsung NX2000 Lens Assembly Replacement: passo 3, immagine 1 di 3 Samsung NX2000 Lens Assembly Replacement: passo 3, immagine 2 di 3 Samsung NX2000 Lens Assembly Replacement: passo 3, immagine 3 di 3
    • Remove the four 4mm screws highlighted here with the Y0 screwdriver.
    • Using a tweezer, gently remove the outer silver lens lining.
    • Underneath will lie a black ring, which needs to removed using the same tweezer.
  4. Samsung NX2000 Lens Assembly Replacement: passo 4, immagine 1 di 3 Samsung NX2000 Lens Assembly Replacement: passo 4, immagine 2 di 3 Samsung NX2000 Lens Assembly Replacement: passo 4, immagine 3 di 3
    • Remove the final silver ring from the lens assembly using a tweezer.
    • Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
    • Remove the spring from the same compartment using the same tool.
Conclusione
USF Tampa, Team 7-4, Cheng Spring 2016 Membro di USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 874
