Salta al contenuto principale
Samsung NX2000 Battery Replacement
  1. Samsung NX2000 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place the camera upside down with the lens facing you.
  2. Samsung NX2000 Battery Replacement: passo 2, immagine 1 di 1
    • Locate the sliding latch on the right side of the camera and slide the latch to the left side to open up the battery compartment.
  3. Samsung NX2000 Battery Replacement: passo 3, immagine 1 di 1
    • Locate the blue release lever holding the battery down. Slide the blue lever to the right to release the battery itself.
  4. Samsung NX2000 Battery Replacement: passo 4, immagine 1 di 1
    • The battery will now slide up about an inch allowing the battery to be pulled out of the camera.
  5. Samsung NX2000 Battery Replacement: passo 5, immagine 1 di 1
    • Insert the new battery with the arrow on the battery pointing into the camera. The red square indicates the location of the arrow.
Conclusione
David Edbom
Membro da: 02/09/16
119 Reputazione
1 Guida realizzata
USF Tampa, Team 7-4, Cheng Spring 2016 Membro di USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 848
