Salta al contenuto principale
Samsung NX1 Back Cover Replacement
Cosa ti serve
  1. Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: passo 1, immagine 1 di 2 Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: passo 1, immagine 2 di 2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Back Cover Replacement: passo 2, immagine 1 di 2 Samsung NX1 Back Cover Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Back Cover Replacement, Back Cover: passo 3, immagine 1 di 3 Samsung NX1 Back Cover Replacement, Back Cover: passo 3, immagine 2 di 3 Samsung NX1 Back Cover Replacement, Back Cover: passo 3, immagine 3 di 3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Back Cover Replacement: passo 4, immagine 1 di 2 Samsung NX1 Back Cover Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Back Cover Replacement: passo 5, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Back Cover Replacement: passo 6, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Back Cover Replacement: passo 7, immagine 1 di 3 Samsung NX1 Back Cover Replacement: passo 7, immagine 2 di 3 Samsung NX1 Back Cover Replacement: passo 7, immagine 3 di 3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Back Cover Replacement: passo 8, immagine 1 di 2 Samsung NX1 Back Cover Replacement: passo 8, immagine 2 di 2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Back Cover Replacement: passo 9, immagine 1 di 3 Samsung NX1 Back Cover Replacement: passo 9, immagine 2 di 3 Samsung NX1 Back Cover Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
Conclusione
USF Tampa, Team 1-4, Leahy Spring 2016 Membro di USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 991
