Salta al contenuto principale
Samsung NX Mini Sensor Replacement
Cosa ti serve
  1. Samsung NX Mini Sensor Replacement, Battery: passo 1, immagine 1 di 3 Samsung NX Mini Sensor Replacement, Battery: passo 1, immagine 2 di 3 Samsung NX Mini Sensor Replacement, Battery: passo 1, immagine 3 di 3
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Sensor Replacement: passo 2, immagine 1 di 2 Samsung NX Mini Sensor Replacement: passo 2, immagine 2 di 2
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
    my battery is stuck, is there a manual release button or a way to remove the battery safely?
    beat70 - Replica
  3. Samsung NX Mini Sensor Replacement, Front Case: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Sensor Replacement: passo 4, immagine 1 di 1
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
    You don't show us how to remove the top plate
    Bev Curran - Replica
  5. Samsung NX Mini Sensor Replacement: passo 5, immagine 1 di 1
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Sensor Replacement: passo 6, immagine 1 di 1
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Sensor Replacement: passo 7, immagine 1 di 1
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Sensor Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Sensor Replacement: passo 9, immagine 1 di 2 Samsung NX Mini Sensor Replacement: passo 9, immagine 2 di 2
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini Sensor Replacement, Sensor: passo 10, immagine 1 di 3 Samsung NX Mini Sensor Replacement, Sensor: passo 10, immagine 2 di 3 Samsung NX Mini Sensor Replacement, Sensor: passo 10, immagine 3 di 3
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini Sensor Replacement: passo 11, immagine 1 di 2 Samsung NX Mini Sensor Replacement: passo 11, immagine 2 di 2
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini Sensor Replacement: passo 12, immagine 1 di 3 Samsung NX Mini Sensor Replacement: passo 12, immagine 2 di 3 Samsung NX Mini Sensor Replacement: passo 12, immagine 3 di 3
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini Sensor Replacement: passo 13, immagine 1 di 2 Samsung NX Mini Sensor Replacement: passo 13, immagine 2 di 2
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini Sensor Replacement: passo 14, immagine 1 di 1
    • Gently remove the sensor mount from the camera case.
Conclusione
To reassemble your camera, follow these instructions in reverse order.
Kelsea Weber
Membro da: 11/12/15
19.876 Reputazione
32 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.141 Guide realizzate
Un commento
Hello,
I need to know the exact dimensions of the IR-cut filter in the Samsung NX Mini camera, which should be just above the sensor. Could you possibly give me that information? I need that because I’d like to modify my NX Mini camera and change it into an infrared camera. I have to cut an infrared filter in the right size, before the disassembly of the camera.
Thank you!
Siamak ADN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,183
