Salta al contenuto principale
Samsung NP900X4B Wifi Card Replacement
Cosa ti serve
  1. Samsung NP900X4B Wifi Card Replacement, Wifi Card: passo 1, immagine 1 di 1
    • This guide should be attempted after the removal of the back panel is completed.
    • The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
  2. Samsung NP900X4B Wifi Card Replacement: passo 2, immagine 1 di 1
    • In order to continue, you need to observe the inside of the laptop and find where the Wifi Card is located.
  3. Samsung NP900X4B Wifi Card Replacement: passo 3, immagine 1 di 1
    • After finding the Wifi Card, you will discover two more 2.5mm Phillips #00 screws which hold the card in place.
    • The screws locations are shown in the image.
    • The same bit piece will be used to unscrew these (PH00/PH000). After completing this continue to the next step.
  4. Samsung NP900X4B Wifi Card Replacement: passo 4, immagine 1 di 2 Samsung NP900X4B Wifi Card Replacement: passo 4, immagine 2 di 2
    • There will be two wires connecting to the Wifi Card from the laptop.
    • These wires can be removed with one of the plastic tools in the iFixit toolkit by applying slight force onto them.
    • After removing the wires move on to the next step.
  5. Samsung NP900X4B Wifi Card Replacement: passo 5, immagine 1 di 2 Samsung NP900X4B Wifi Card Replacement: passo 5, immagine 2 di 2
    • This last step is the easiest of them all, all you need to do it pick up the Wifi Card from its position and you're done!
    • Now you are able to replace the card by following these steps in reverse or have the card further repaired.
Conclusione
Jacob Drohan
Membro da: 10/15/18
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 209
