Salta al contenuto principale
Samsung NP900X4B Fan Replacement
Cosa ti serve
  1. Samsung NP900X4B Fan Replacement, Back Panel: passo 1, immagine 1 di 2 Samsung NP900X4B Fan Replacement, Back Panel: passo 1, immagine 2 di 2
    • First turn the computer over so you are looking at the back panel.
    • Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
  2. Samsung NP900X4B Fan Replacement: passo 2, immagine 1 di 1
    • Next remove all 3.5mm Phillips #0 screws shown in the previous step.
  3. Samsung NP900X4B Fan Replacement: passo 3, immagine 1 di 2 Samsung NP900X4B Fan Replacement: passo 3, immagine 2 di 2
    • After all screws are removed, lift up the back panel as shown.
  4. Samsung NP900X4B Fan Replacement, Fan: passo 4, immagine 1 di 2 Samsung NP900X4B Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  5. Samsung NP900X4B Fan Replacement: passo 5, immagine 1 di 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  6. Samsung NP900X4B Fan Replacement: passo 6, immagine 1 di 2 Samsung NP900X4B Fan Replacement: passo 6, immagine 2 di 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  7. Samsung NP900X4B Fan Replacement: passo 7, immagine 1 di 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
Conclusione
Brian Miller
Membro da: 10/17/18
333 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 174
