Salta al contenuto principale
Samsung NP700Z5AH Display Replacement
Cosa ti serve
  1. Samsung NP700Z5AH Display Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Display Replacement: passo 2, immagine 1 di 3 Samsung NP700Z5AH Display Replacement: passo 2, immagine 2 di 3 Samsung NP700Z5AH Display Replacement: passo 2, immagine 3 di 3
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Display Replacement: passo 3, immagine 1 di 2 Samsung NP700Z5AH Display Replacement: passo 3, immagine 2 di 2
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Display Replacement: passo 4, immagine 1 di 2 Samsung NP700Z5AH Display Replacement: passo 4, immagine 2 di 2
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Display Replacement: passo 5, immagine 1 di 1
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Display Replacement: passo 6, immagine 1 di 2 Samsung NP700Z5AH Display Replacement: passo 6, immagine 2 di 2
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
  7. Samsung NP700Z5AH Display Replacement, Display: passo 7, immagine 1 di 2 Samsung NP700Z5AH Display Replacement, Display: passo 7, immagine 2 di 2
    • Place the tip of the spudger under the metal caps of the black and grey coaxial connectors and pry upwards to disconnect them.
    • After they are disconnected, un-thread the coaxial connectors from around the fan.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors "snap" into their sockets much like the metal snaps on a jacket.
  8. Samsung NP700Z5AH Display Replacement: passo 8, immagine 1 di 3 Samsung NP700Z5AH Display Replacement: passo 8, immagine 2 di 3 Samsung NP700Z5AH Display Replacement: passo 8, immagine 3 di 3
    • Using the Phillips#00, remove the single 3.5mm screw from the wireless card.
    • Grasp the edges of the wireless card with your fingers and pull straight backwards to remove it.
  9. Samsung NP700Z5AH Display Replacement: passo 9, immagine 1 di 2 Samsung NP700Z5AH Display Replacement: passo 9, immagine 2 di 2
    • Using the Phillips#00, remove the six 4.5mm screws from the corner brackets holding the display to the inner case.
  10. Samsung NP700Z5AH Display Replacement: passo 10, immagine 1 di 3 Samsung NP700Z5AH Display Replacement: passo 10, immagine 2 di 3 Samsung NP700Z5AH Display Replacement: passo 10, immagine 3 di 3
    • Using your fingers, grasp the edges of the inner case then lift and pull away to separate it from the display.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 835
