Salta al contenuto principale
Samsung NP540U3C-A02UB Fan Replacement
Cosa ti serve
  1. Samsung NP540U3C-A02UB Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Turn off the laptop and disconnect from the charging cable before beginning disassembly.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Fan Replacement: passo 2, immagine 1 di 2 Samsung NP540U3C-A02UB Fan Replacement: passo 2, immagine 2 di 2
    • Remove the 1x 4mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Fan Replacement: passo 3, immagine 1 di 3 Samsung NP540U3C-A02UB Fan Replacement: passo 3, immagine 2 di 3 Samsung NP540U3C-A02UB Fan Replacement: passo 3, immagine 3 di 3
    • Gently release the three clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Fan Replacement: passo 4, immagine 1 di 1
    • Peel the yellow tape up so it no longer blocks the fan's wires and screw.
  5. Samsung NP540U3C-A02UB Fan Replacement: passo 5, immagine 1 di 1
    • Remove the two 2.4mm Phillips #00 screws attaching the fan to the case.
    • Remove the two 6mm Phillips #00 screws attaching the fan to the case.
  6. Samsung NP540U3C-A02UB Fan Replacement: passo 6, immagine 1 di 2 Samsung NP540U3C-A02UB Fan Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, gently disconnect the fan from the motherboard by unplugging the wire.
  7. Samsung NP540U3C-A02UB Fan Replacement: passo 7, immagine 1 di 1
    • Remove the fan from the case.
Conclusione
Colby Bolger
Membro da: 03/28/22
277 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 432
