Introduzione
Random Access Memory (RAM) is a critical part of any device, it assists the device to run smoothly. This guide will show you how to replace it properly.
Cosa ti serve
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Press down on the tabs on both sides of the RAM to release, then pull away from the mount to remove.
Black bullet. Pulling out the RAM with tweezers better, no? Is that the only bolt there is to access RAM?
