Introduzione
The display for a device gives visual output for the user to interact with. This guide will help you replace it properly.
Cosa ti serve
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Unplug the connector from the hard drive by pulling straight out.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
Disconnect the last cable by pulling straight out.
