Introduzione
The battery is the power source for the device, without it the device is useless. This guide will help you replace it properly.
Cosa ti serve
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
Altre 2 persone hanno completato questa guida.
