Salta al contenuto principale
Samsung NP510R5E-A01UB Battery Replacement
Cosa ti serve
  1. Samsung NP510R5E-A01UB Battery Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Battery Replacement: passo 2, immagine 1 di 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Battery Replacement: passo 3, immagine 1 di 2 Samsung NP510R5E-A01UB Battery Replacement: passo 3, immagine 2 di 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Battery Replacement, Battery: passo 4, immagine 1 di 3 Samsung NP510R5E-A01UB Battery Replacement, Battery: passo 4, immagine 2 di 3 Samsung NP510R5E-A01UB Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Battery Replacement: passo 5, immagine 1 di 3 Samsung NP510R5E-A01UB Battery Replacement: passo 5, immagine 2 di 3 Samsung NP510R5E-A01UB Battery Replacement: passo 5, immagine 3 di 3
    • Use the screwdriver to remove the four 3.5mm long screws holding the battery in place. Then carefully pull the battery's connector cable out to remove the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Brian Briggs
Membro da: 02/14/18
529 Reputazione
4 Guide realizzate
USF Tampa, Team S6-G5, Eyestone Spring 2018 Membro di USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,407
