Salta al contenuto principale
Samsung NP510R5E-A01UB Back Case Replacement
Cosa ti serve
  1. Samsung NP510R5E-A01UB Back Case Replacement, Back Case: passo 1, immagine 1 di 3 Samsung NP510R5E-A01UB Back Case Replacement, Back Case: passo 1, immagine 2 di 3 Samsung NP510R5E-A01UB Back Case Replacement, Back Case: passo 1, immagine 3 di 3
    • Lightly press down on the the back panel and pull away from the back case. The panel should slide away and detach from the back case.
  2. Samsung NP510R5E-A01UB Back Case Replacement: passo 2, immagine 1 di 2 Samsung NP510R5E-A01UB Back Case Replacement: passo 2, immagine 2 di 2
    • Remove the two rubber feet that have arrows pointing towards them. The rubber feet are very sticky so use the metal spudger to pry them up.
  3. Samsung NP510R5E-A01UB Back Case Replacement: passo 3, immagine 1 di 1
    • Using the JIS #0 screwdriver, remove all the screws in the back case.
    • Unscrew the 9 black 6.5mm screws.
    • Unscrew the 4 silver 4.4mm screws.
  4. Samsung NP510R5E-A01UB Back Case Replacement: passo 4, immagine 1 di 2 Samsung NP510R5E-A01UB Back Case Replacement: passo 4, immagine 2 di 2
    • Using the spudger, insert it between the back case and the laptop. Pry up on the back case until the case pops up. Work the spudger all the way around the back case until the back case will lift off freely.
Conclusione
Sandhal Olds
Membro da: 03/25/19
283 Reputazione
2 Guide realizzate
IUPUI, Team S2-G2, Henning Spring 2019 Membro di IUPUI, Team S2-G2, Henning Spring 2019
IUPUI-HENNING-S19S2G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 358
