Salta al contenuto principale
Samsung NP36535C-S05US Key Replacement
Cosa ti serve
  1. Samsung NP36535C-S05US Key Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US Key Replacement: passo 2, immagine 1 di 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US Key Replacement: passo 3, immagine 1 di 2 Samsung NP36535C-S05US Key Replacement: passo 3, immagine 2 di 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US Key Replacement, Key: passo 4, immagine 1 di 3 Samsung NP36535C-S05US Key Replacement, Key: passo 4, immagine 2 di 3 Samsung NP36535C-S05US Key Replacement, Key: passo 4, immagine 3 di 3
    • There is an outer and inner piece of the retainer. The outer retainer has two (2) grooves for the inner retainer's posts to sit in.
    • Place the inner retainer piece into the outer retainer piece by inserting the posts into the grooves on the outer retainer piece.
  5. Samsung NP36535C-S05US Key Replacement: passo 5, immagine 1 di 3 Samsung NP36535C-S05US Key Replacement: passo 5, immagine 2 di 3 Samsung NP36535C-S05US Key Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    $3.99
    • There are two (2) grooves on the outer retainer that fit onto two (2) metal brackets on the key's designated space.
    • Use angled tweezers to place the assembled retainer onto the two (2) metal brackets on the keyboard.
  6. Samsung NP36535C-S05US Key Replacement: passo 6, immagine 1 di 3 Samsung NP36535C-S05US Key Replacement: passo 6, immagine 2 di 3 Samsung NP36535C-S05US Key Replacement: passo 6, immagine 3 di 3
    • Once the retainer is attached, press the key onto the retainer, it will make a snapping sound when in place.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 430
