Salta al contenuto principale
Introduzione
If the optical drive isn’t working correctly, this guide will help you replace the drive.
Parti
Nessuna parte specificata.
  1. Lay the laptop down so that the bottom is facing up.
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Slide the two plastic tabs to the opposing sides.
    • Slide the two plastic tabs to the opposing sides.
  3. While both are in the unlocked position, slide the battery out.
    • While both are in the unlocked position, slide the battery out.
  4. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  5. Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  6. Slide the cover 1/4" towards the front of the laptop.
    • Slide the cover 1/4" towards the front of the laptop.
  7. Then, lift the cover off.
    • Then, lift the cover off.
  8. Find the screw between the hard drive and the model label. Then remove the M2.5X5 screw with a Phillips #0 screwdriver.
    • Find the screw between the hard drive and the model label. Then remove the M2.5X5 screw with a Phillips #0 screwdriver.
  9. Pull the optical drive straight out.
    • Pull the optical drive straight out.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 78
