Salta al contenuto principale
Samsung NP350E5C-A02US Hard Drive Replacement
Cosa ti serve
  1. Samsung NP350E5C-A02US Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Hard Drive Replacement: passo 3, immagine 1 di 1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Hard Drive Replacement, Hard drive and memory stick cover: passo 4, immagine 1 di 1
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US Hard Drive Replacement: passo 5, immagine 1 di 1
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US Hard Drive Replacement: passo 6, immagine 1 di 1
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 1
    • Slide the hard drive 1/4" towards the front of the laptop.
  8. Samsung NP350E5C-A02US Hard Drive Replacement: passo 8, immagine 1 di 1
    • Then, lift the drive up and out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 439
