Salta al contenuto principale
Samsung NP305E5A-A03US RAM Replacement
Cosa ti serve
  1. Samsung NP305E5A-A03US RAM Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US RAM Replacement: passo 2, immagine 1 di 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US RAM Replacement: passo 3, immagine 1 di 2 Samsung NP305E5A-A03US RAM Replacement: passo 3, immagine 2 di 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US RAM Replacement: passo 4, immagine 1 di 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US RAM Replacement: passo 5, immagine 1 di 2 Samsung NP305E5A-A03US RAM Replacement: passo 5, immagine 2 di 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US RAM Replacement: passo 6, immagine 1 di 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US RAM Replacement, RAM: passo 7, immagine 1 di 1
    • Place your thumbs on the metal tabs.
    • Push outwards on the metal tabs to release the RAM.
  8. Samsung NP305E5A-A03US RAM Replacement: passo 8, immagine 1 di 2 Samsung NP305E5A-A03US RAM Replacement: passo 8, immagine 2 di 2
    • Pull out the RAM towards you to remove it from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Julia Dotter
Membro da: 10/31/16
224 Reputazione
1 Guida realizzata
Baylor, Team 5-7, Williams Fall 2016 Membro di Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 430
