Salta al contenuto principale
Samsung NP305E5A-A03US Optical Drive Replacement
Cosa ti serve
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: passo 2, immagine 1 di 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: passo 3, immagine 1 di 2 Samsung NP305E5A-A03US Optical Drive Replacement: passo 3, immagine 2 di 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: passo 4, immagine 1 di 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: passo 5, immagine 1 di 2 Samsung NP305E5A-A03US Optical Drive Replacement: passo 5, immagine 2 di 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: passo 6, immagine 1 di 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: passo 7, immagine 1 di 1
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: passo 8, immagine 1 di 2 Samsung NP305E5A-A03US Optical Drive Replacement: passo 8, immagine 2 di 2
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: passo 9, immagine 1 di 3 Samsung NP305E5A-A03US Optical Drive Replacement: passo 9, immagine 2 di 3 Samsung NP305E5A-A03US Optical Drive Replacement: passo 9, immagine 3 di 3
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: passo 10, immagine 1 di 2 Samsung NP305E5A-A03US Optical Drive Replacement: passo 10, immagine 2 di 2
    • Remove the Optical Drive by sliding it away from the laptop.
Conclusione
Kris Stobbe
Membro da: 10/30/16
585 Reputazione
3 Guide realizzate
Baylor, Team 5-7, Williams Fall 2016 Membro di Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 333
