Salta al contenuto principale
Samsung NP305E5A-A03US Battery Replacement
  1. Samsung NP305E5A-A03US Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Battery Replacement: passo 2, immagine 1 di 1
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Battery Replacement: passo 3, immagine 1 di 2 Samsung NP305E5A-A03US Battery Replacement: passo 3, immagine 2 di 2
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
Conclusione
Altre 3 persone hanno completato questa guida.
Kris Stobbe
Membro da: 10/30/16
585 Reputazione
3 Guide realizzate
Baylor, Team 5-7, Williams Fall 2016 Membro di Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 543
