Salta al contenuto principale
Samsung NP300E5C Screen Replacement
Cosa ti serve
  1. Samsung NP300E5C Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Screen Replacement: passo 2, immagine 1 di 3 Samsung NP300E5C Screen Replacement: passo 2, immagine 2 di 3 Samsung NP300E5C Screen Replacement: passo 2, immagine 3 di 3
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Screen Replacement, Screen: passo 3, immagine 1 di 1
    • Turn the laptop over and open it so that you can see the keyboard and screen.
    • Using a Phillips #000 screwdriver, remove the two 4 mm Phillips #8 screws that are under the black covers on the front of your screen.
    • You can remove the black covers by simply pushing your screwdriver into them.
  4. Samsung NP300E5C Screen Replacement: passo 4, immagine 1 di 3 Samsung NP300E5C Screen Replacement: passo 4, immagine 2 di 3 Samsung NP300E5C Screen Replacement: passo 4, immagine 3 di 3
    • Insert the plastic opening tool into the seam on the top of the screen.
    • The seam is where the back screen cover and the plastic bezel around the edges of the screen meet.
    • Use the plastic opening tool to pop open the clasps that keep the casing on the screen.
    • It helps to use the plastic opening tool like a crowbar.
    • Follow this seam around the laptop's screen with the plastic opening tool until the plastic cover comes off.
    • Don't be afraid to use your fingers to help pop open the clips.
  5. Samsung NP300E5C Screen Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the top two 4 mm Phillips #8 screws that join the LCD screen to the plastic casing.
    • Using the same screwdriver, remove the bottom four 4 mm Phillips #8 screws that mount the screen onto the base of the laptop.
    • As you remove these bottom 4 screws, support the screen! As the screws come off, the screen will begin to fall backwards.
  6. Samsung NP300E5C Screen Replacement: passo 6, immagine 1 di 3 Samsung NP300E5C Screen Replacement: passo 6, immagine 2 di 3 Samsung NP300E5C Screen Replacement: passo 6, immagine 3 di 3
    • Gently lay the LCD on the keyboard, and lay down the back panel of the screen as well. They are not attached and will separate easily.
    • The LCD and the back panel must remain close to one another due to the video connector at the bottom that links the two.
    • Remove the tape that secures the video connector to the LCD.
    • While maintaining a firm grip on the LCD, grasp the video connector at its base, and pull it away from you.
    • Don't be afraid to pull, the video connector is not soldered onto the LCD.
Conclusione
Altre 10 persone hanno completato questa guida.
aliahsan95
Membro da: 09/23/15
937 Reputazione
4 Guide realizzate
Baylor, Team 10-13, Williams Fall 2015 Membro di Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 6,285
