Introduzione
Is your laptop's screen cracked or non responsive? Try replacing it! This guide will show you how to remove the screen's plastic casing so that you can access the screen itself.
Cosa ti serve
Turn the laptop over and open it so that you can see the keyboard and screen.
Using a Phillips #000 screwdriver, remove the two 4 mm Phillips #8 screws that are under the black covers on the front of your screen.
Gently lay the LCD on the keyboard, and lay down the back panel of the screen as well. They are not attached and will separate easily.
Remove the tape that secures the video connector to the LCD.
While maintaining a firm grip on the LCD, grasp the video connector at its base, and pull it away from you.
Altre 10 persone hanno completato questa guida.
