Salta al contenuto principale
Introduzione
A faulty hard drive can be the underlying cause of many issues with a laptop. This guide will take your through the steps necessary to replace the hard drive so you can get back to using your computer.
Parti
Nessuna parte specificata.
  1. Lay laptop down so that the bottom is facing the sky.
    • Lay laptop down so that the bottom is facing the sky.
  2. Push both tabs away from the center of the device. While both are in the fully unlocked position, slide the battery out. While both are in the fully unlocked position, slide the battery out.
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver. Firmly, but gently pull the cover towards you. After moving the cover about 2 centimeters, you can lift and remove it.
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
    • Firmly, but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  4. Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver. Gently lift the hard drive up, however do not remove it. Gently lift the hard drive up, however do not remove it.
    • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
    • Gently lift the hard drive up, however do not remove it.
  5. Firmly grasp the base of the connector at the bottom of the hard drive. Gently pull the connector off to free the hard drive.
    • Firmly grasp the base of the connector at the bottom of the hard drive.
    • Gently pull the connector off to free the hard drive.
Conclusione
Altre 9 persone hanno completato questa guida.
aliahsan95
Membro da: 23/09/2015
835 Reputazione
4 Guide realizzate
Baylor, Team 10-13, Williams Fall 2015 Membro di Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Membri
4 Guide realizzate
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 152
Tutti i Tempi: 6,226
