Introduzione
A faulty hard drive can be the underlying cause of many issues with a laptop. This guide will take your through the steps necessary to replace the hard drive so you can get back to using your computer.
Cosa ti serve
Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
Firmly, but gently pull the cover towards you.
After moving the cover about 2 centimeters, you can lift and remove it.
Altre 11 persone hanno completato questa guida.
2 Commenti
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B -
