Salta al contenuto principale
Samsung NP300E5C Hard Drive Replacement
Cosa ti serve
  1. Samsung NP300E5C Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Hard Drive Replacement: passo 2, immagine 1 di 3 Samsung NP300E5C Hard Drive Replacement: passo 2, immagine 2 di 3 Samsung NP300E5C Hard Drive Replacement: passo 2, immagine 3 di 3
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
    • Firmly, but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  4. Samsung NP300E5C Hard Drive Replacement: passo 4, immagine 1 di 3 Samsung NP300E5C Hard Drive Replacement: passo 4, immagine 2 di 3 Samsung NP300E5C Hard Drive Replacement: passo 4, immagine 3 di 3
    • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
    • Gently lift the hard drive up, however do not remove it.
  5. Samsung NP300E5C Hard Drive Replacement: passo 5, immagine 1 di 2 Samsung NP300E5C Hard Drive Replacement: passo 5, immagine 2 di 2
    • Firmly grasp the base of the connector at the bottom of the hard drive.
    • Gently pull the connector off to free the hard drive.
Conclusione
Altre 11 persone hanno completato questa guida.
aliahsan95
Membro da: 09/23/15
937 Reputazione
4 Guide realizzate
Baylor, Team 10-13, Williams Fall 2015 Membro di Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Membri
4 Guide realizzate
2 Commenti
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - Replica
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 12,335
