Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
If you find that your laptop dies unexpectedly, or does not charge, a battery replacement may be in order. This guide will help you replace your current battery with a new one.
  1. Lay laptop down so that the bottom is facing the sky.
    • Lay laptop down so that the bottom is facing the sky.
  2. Push both tabs away from the center of the device. While both are in the fully unlocked position, slide the battery out. While both are in the fully unlocked position, slide the battery out.
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
Conclusione
Altre 2 persone hanno completato questa guida.
aliahsan95
Membro da: 23/09/2015
850 Reputazione
4 Guide realizzate
Baylor, Team 10-13, Williams Fall 2015 Membro di Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,106
