Salta al contenuto principale
Samsung NP270E5E-K03US RAM Replacement
Cosa ti serve
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: passo 1, immagine 1 di 2 Samsung NP270E5E-K03US RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: passo 2, immagine 1 di 2 Samsung NP270E5E-K03US RAM Replacement: passo 2, immagine 2 di 2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Remove the 4mm screw with a Phillips #0 screwdriver.
  4. Samsung NP270E5E-K03US RAM Replacement: passo 4, immagine 1 di 3 Samsung NP270E5E-K03US RAM Replacement: passo 4, immagine 2 di 3 Samsung NP270E5E-K03US RAM Replacement: passo 4, immagine 3 di 3
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: passo 5, immagine 1 di 3 Samsung NP270E5E-K03US RAM Replacement: passo 5, immagine 2 di 3 Samsung NP270E5E-K03US RAM Replacement: passo 5, immagine 3 di 3
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: passo 6, immagine 1 di 1
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
Conclusione
Kyle Golden
Membro da: 03/23/17
353 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,136
