Introduzione
In this guide you will learn how to remove the back cover in order to access and replace a damaged or broken hard drive.
Cosa ti serve
Begin with the laptop lying to its back revealing its underside.
Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
Altre 3 persone hanno completato questa guida.
