Salta al contenuto principale
Samsung NP270E5E-K03US Hard Drive Replacement
Cosa ti serve
  1. Samsung NP270E5E-K03US Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Samsung NP270E5E-K03US Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US Hard Drive Replacement: passo 2, immagine 1 di 2 Samsung NP270E5E-K03US Hard Drive Replacement: passo 2, immagine 2 di 2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
  4. Samsung NP270E5E-K03US Hard Drive Replacement: passo 4, immagine 1 di 2 Samsung NP270E5E-K03US Hard Drive Replacement: passo 4, immagine 2 di 2
    • Locate the gray hard drive cover, and remove the four corner 3.5mm screws.
  5. Samsung NP270E5E-K03US Hard Drive Replacement: passo 5, immagine 1 di 2 Samsung NP270E5E-K03US Hard Drive Replacement: passo 5, immagine 2 di 2
    • Lift the hard drive cover by pulling upwards on the removal handle.
    • You can now remove the hard drive from the laptops housing freeing up space to replace your damaged or broken hard drive with a new hard drive.
Conclusione
Altre 3 persone hanno completato questa guida.
Kyle Golden
Membro da: 03/23/17
353 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,693
