Salta al contenuto principale
Samsung NP-RF411 Laptop Maintenance
Cosa ti serve
  1. Samsung NP-RF411 Laptop Maintenance, Laptop: passo 1, immagine 1 di 2 Samsung NP-RF411 Laptop Maintenance, Laptop: passo 1, immagine 2 di 2
    • Quite a simple stage. There are a total of 19 screws to be removed from the bottom of the casing.
    • Three for HDD
    • One for Ram/HDD Cover
    • One for ODD
    • one hidden under a rubber foot at the front of the laptop.
    • Three under the Battery
    • Make sure you remove the fake SD Card at the front, because this can stall you.
  2. Samsung NP-RF411 Laptop Maintenance: passo 2, immagine 1 di 3 Samsung NP-RF411 Laptop Maintenance: passo 2, immagine 2 di 3 Samsung NP-RF411 Laptop Maintenance: passo 2, immagine 3 di 3
    • Once the cover is off, there are three screws holding the main PCB down.
    • Screws for the HDD
    • Battery. DC 11.1V 57W
  3. Samsung NP-RF411 Laptop Maintenance: passo 3, immagine 1 di 2 Samsung NP-RF411 Laptop Maintenance: passo 3, immagine 2 di 2
    • This shows the main PCB
    • USB 3.0 Ports
  4. Samsung NP-RF411 Laptop Maintenance: passo 4, immagine 1 di 3 Samsung NP-RF411 Laptop Maintenance: passo 4, immagine 2 di 3 Samsung NP-RF411 Laptop Maintenance: passo 4, immagine 3 di 3
    • locations of the main PCB / WIFI card screws.
  5. Samsung NP-RF411 Laptop Maintenance: passo 5, immagine 1 di 3 Samsung NP-RF411 Laptop Maintenance: passo 5, immagine 2 di 3 Samsung NP-RF411 Laptop Maintenance: passo 5, immagine 3 di 3
    • removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side.
  6. Samsung NP-RF411 Laptop Maintenance: passo 6, immagine 1 di 2 Samsung NP-RF411 Laptop Maintenance: passo 6, immagine 2 di 2
    • Here's the underside of the main PCB, all cables detached.
    • With the PCB removed this is all you have left.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
My laptop motherboard heat why?
The Media Sound Rec. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,364
