Salta al contenuto principale
Samsung NP-NC10-KA02US Hard Drive Replacement
Cosa ti serve
  1. Samsung NP-NC10-KA02US Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Samsung NP-NC10-KA02US Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 2, immagine 1 di 1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US Hard Drive Replacement, Back Plate: passo 4, immagine 1 di 1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 6, immagine 1 di 2 Samsung NP-NC10-KA02US Hard Drive Replacement: passo 6, immagine 2 di 2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 2 Samsung NP-NC10-KA02US Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Locate the hard drive.
    • Remove the one 3.93 mm screw holding the hard drive in place using a PH1 screw bit.
  8. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 8, immagine 1 di 2 Samsung NP-NC10-KA02US Hard Drive Replacement: passo 8, immagine 2 di 2
    • Hold the end of the hard drive farthest from where it is connected to the netbook. Then gently pull in the opposite direction of where the hard drive is connected.
    • Your hard drive is now removed.
Conclusione
Altre 5 persone hanno completato questa guida.
Brian Smith
Membro da: 10/03/16
405 Reputazione
2 Guide realizzate
USF Tampa, Team 1-1, Sullivan Fall 2016 Membro di USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 Membri
6 Guide realizzate
2 Commenti
Thanks for your kindness.
นพไกร ใจดี - Replica
Where can I get the screws from
Lucky Jacob - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 46
Tutti i Tempi: 6,071
