Salta al contenuto principale
Samsung NP-N210-JA02US Wireless Card Replacement
Cosa ti serve
  1. Samsung NP-N210-JA02US Wireless Card Replacement, Battery: passo 1, immagine 1 di 2 Samsung NP-N210-JA02US Wireless Card Replacement, Battery: passo 1, immagine 2 di 2
    • Carefully slide both locking pins to the unlocked position.
  2. Samsung NP-N210-JA02US Wireless Card Replacement: passo 2, immagine 1 di 1
    • Slide the battery out of its housing.
  3. Samsung NP-N210-JA02US Wireless Card Replacement, Battery Removal: passo 3, immagine 1 di 1
    • Remove the following 14 screws:
    • Thirteen 5 mm Phillips #1 screws
    • One 3.5 mm Philips #001 screw
  4. Samsung NP-N210-JA02US Wireless Card Replacement: passo 4, immagine 1 di 1
    • Carefully insert the plastic opening tool in the seam between the lower casing and the chrome bezel.
  5. Samsung NP-N210-JA02US Wireless Card Replacement: passo 5, immagine 1 di 1
    • Slide the opening tool across all sides of the lower case, and lift it up to remove the case and reveal the internal components.
  6. Samsung NP-N210-JA02US Wireless Card Replacement: passo 6, immagine 1 di 1
    • Locate the wireless card.
  7. Samsung NP-N210-JA02US Wireless Card Replacement: passo 7, immagine 1 di 1
    • Remove the 3.5 mm Philips #1 screw.
  8. Samsung NP-N210-JA02US Wireless Card Replacement: passo 8, immagine 1 di 2 Samsung NP-N210-JA02US Wireless Card Replacement: passo 8, immagine 2 di 2
    • Carefully with tweezers, lift both connectors to disconnect them from the wireless card.
  9. Samsung NP-N210-JA02US Wireless Card Replacement: passo 9, immagine 1 di 1
    • Gently remove the wireless card from its socket.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 1-3, Nance Fall 2016 Membro di USF Tampa, Team 1-3, Nance Fall 2016
USFT-NANCE-F16S1G3
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 345
