Salta al contenuto principale
Samsung NP-N145-JP02US Screen Replacement
Cosa ti serve
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: passo 2, immagine 1 di 1
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: passo 3, immagine 1 di 1
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: passo 4, immagine 1 di 3 Samsung NP-N145-JP02US Screen Replacement: passo 4, immagine 2 di 3 Samsung NP-N145-JP02US Screen Replacement: passo 4, immagine 3 di 3
    • Using your fingertips, gently pull screen to pop it out of the frame.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 21
Tutti i Tempi: 361
