Salta al contenuto principale
Samsung NP-N145-JP02US Fan Replacement
Cosa ti serve
  1. Samsung NP-N145-JP02US Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Before starting the replacement, turn off the device sure and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Fan Replacement: passo 2, immagine 1 di 1
    • Remove the back of the device from the main frame by unscrewing the 14 4.5 mm screws using a Phillips #0 screwdriver.
    • Once all screws are out, pry open the back cover piece of the device using a plastic opening tool.
  3. Samsung NP-N145-JP02US Fan Replacement: passo 3, immagine 1 di 1
    • Remove the four 6.5 mm screws that surround the fan using the PH1 Phillips screwdriver head.
  4. Samsung NP-N145-JP02US Fan Replacement: passo 4, immagine 1 di 1
    • Manually remove the fan from the device by pulling out the connector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 582
