Salta al contenuto principale
Samsung NP-N102S-B05PH Speaker Replacement
Cosa ti serve
  1. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: passo 1, immagine 1 di 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: passo 1, immagine 2 di 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Place the laptop face-down on a stable surface.
    • Remove the nine 6.5mm Phillips #0 screws shown.
    • Use the blue opening tool to gently pry the back of the laptop off of the body.
  2. Samsung NP-N102S-B05PH Speaker Replacement: passo 2, immagine 1 di 3 Samsung NP-N102S-B05PH Speaker Replacement: passo 2, immagine 2 di 3 Samsung NP-N102S-B05PH Speaker Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the six 4.5mm screws holding the motherboard to the case.
  3. Samsung NP-N102S-B05PH Speaker Replacement: passo 3, immagine 1 di 2 Samsung NP-N102S-B05PH Speaker Replacement: passo 3, immagine 2 di 2
    • Use the spudger to remove the red and black cable located above the speaker from it's connector.
    • Also using the spudger, remove the small ribbon cable located a the bottom of the motherboard, towards the middle.
    • Fold the motherboard back, using the computer hinge as the axis of rotation. The motherboard will still be attached to the case by a few wires.
  4. Samsung NP-N102S-B05PH Speaker Replacement: passo 4, immagine 1 di 1
    • Gently unhook the red and black wires from the plastic clips holding them to the case. This can be done with only your fingers.
  5. Samsung NP-N102S-B05PH Speaker Replacement: passo 5, immagine 1 di 1
    • Using the spudger, lift the speaker up and out of it's holder, as shown. The yellow plastic tape should peel off as well.
Conclusione
Lennon Grimm
Membro da: 10/04/16
247 Reputazione
2 Guide realizzate
USF Tampa, Team 2-4, Nance Fall 2016 Membro di USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,089
