Cosa ti serve
Place the laptop face-down on a stable surface.
Remove the nine 6.5mm Phillips #0 screws shown.
Use the blue opening tool to gently pry the back of the laptop off of the body.
Use the spudger to remove the red and black cable located above the speaker from it's connector.
Also using the spudger, remove the small ribbon cable located a the bottom of the motherboard, towards the middle.
Fold the motherboard back, using the computer hinge as the axis of rotation. The motherboard will still be attached to the case by a few wires.
