Salta al contenuto principale
Samsung NP-N102S-B05PH Hard Drive Replacement
Cosa ti serve
  1. Samsung NP-N102S-B05PH Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Before replacing a hard drive, have a backup of original files if files are needed to be recovered afterward.
    • Power down your laptop, and position the laptop with the bottom cover facing upwards.
  2. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the nine 6.5 mm screws.
  3. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use an opening to pry off the bottom cover, clips.
    • Potential for device damage. Before proceeding, be sure to be grounded, as existing static can be transferred and cause significant damage to the device. Wear an anti-static wristband for additional protection.
  4. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 4, immagine 1 di 3 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 4, immagine 2 di 3 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the four 4.5 mm bracket screws holding the hard drive onto the motherboard.
    • Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
  5. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 5, immagine 1 di 3 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 5, immagine 2 di 3 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 5, immagine 3 di 3
    • Lift the hard drive up and gently pull off the SATA cable that is currently connected to the board.
    • The hard drive is now fully removed from the laptop.
Conclusione
Daniel Rudzik
Membro da: 10/04/16
349 Reputazione
3 Guide realizzate
USF Tampa, Team 2-4, Nance Fall 2016 Membro di USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,619
