Salta al contenuto principale
Samsung NP-130-JA01US RAM Replacement
Cosa ti serve
  1. Samsung NP-130-JA01US RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US RAM Replacement: passo 2, immagine 1 di 2 Samsung NP-130-JA01US RAM Replacement: passo 2, immagine 2 di 2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US RAM Replacement: passo 3, immagine 1 di 1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US RAM Replacement, RAM: passo 4, immagine 1 di 2 Samsung NP-130-JA01US RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Locate the "Memory" panel on the bottom right corner.
    • Use the Phillips 01 screwdriver to remove the screw.
    • The screw is a Phillips 1 (PH 1) with a length of 60 millimeters (mm)
  5. Samsung NP-130-JA01US RAM Replacement: passo 5, immagine 1 di 1
    • With your hand, lift panel and remove it.
  6. Samsung NP-130-JA01US RAM Replacement: passo 6, immagine 1 di 2 Samsung NP-130-JA01US RAM Replacement: passo 6, immagine 2 di 2
    • Slide metal prongs (marked in red squares) away from each other with your fingers.
    • The RAM chip will automatically lift up at an angle for easy ejection.
  7. Samsung NP-130-JA01US RAM Replacement: passo 7, immagine 1 di 1
    • With your hands, carefully slide the RAM chip out to remove.
    • The RAM chip is delicate, do not force it when removing it.
Conclusione
USF Tampa, Team 9-6, Lacy Fall 2016 Membro di USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 203
