Salta al contenuto principale
Samsung NP N310 HAA2US RAM Replacement
Cosa ti serve
  1. Samsung NP N310 HAA2US RAM Replacement, Battery: passo 1, immagine 1 di 3 Samsung NP N310 HAA2US RAM Replacement, Battery: passo 1, immagine 2 di 3 Samsung NP N310 HAA2US RAM Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US RAM Replacement, RAM: passo 2, immagine 1 di 3 Samsung NP N310 HAA2US RAM Replacement, RAM: passo 2, immagine 2 di 3 Samsung NP N310 HAA2US RAM Replacement, RAM: passo 2, immagine 3 di 3
    • Locate and unscrew the 5mm screw on the small panel on the back that has 'memory' written on it.
    • Pull off the memory panel.
  3. Samsung NP N310 HAA2US RAM Replacement: passo 3, immagine 1 di 3 Samsung NP N310 HAA2US RAM Replacement: passo 3, immagine 2 di 3 Samsung NP N310 HAA2US RAM Replacement: passo 3, immagine 3 di 3
    • Pull the 2 latches holding the RAM in, away from the RAM stick, and the RAM will pop up.
    • Pull the RAM out of the slot, only touching the edges of the RAM stick
Conclusione
Amir Afridi
Membro da: 09/29/16
626 Reputazione
6 Guide realizzate
USF Tampa, Team 4-1, Passmore Fall 2016 Membro di USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Membri
6 Guide realizzate
Un commento
I checked out this guide today (11.2022) to upgrade the RAM in my N310 Windows XP laptop that I bought in the summer of 2009 : ) a whooping 2 GB of DDR2 RAM installed to play old games on original hardware... yee haw!
Mick Germ - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 287
