Salta al contenuto principale
Samsung NP N310 HAA2US Hard Drive Replacement
Cosa ti serve
  1. Samsung NP N310 HAA2US Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Samsung NP N310 HAA2US Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Samsung NP N310 HAA2US Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Hard Drive Replacement, Back Panel: passo 2, immagine 1 di 2 Samsung NP N310 HAA2US Hard Drive Replacement, Back Panel: passo 2, immagine 2 di 2
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Hard Drive Replacement: passo 3, immagine 1 di 3 Samsung NP N310 HAA2US Hard Drive Replacement: passo 3, immagine 2 di 3 Samsung NP N310 HAA2US Hard Drive Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
  4. Samsung NP N310 HAA2US Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Samsung NP N310 HAA2US Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Samsung NP N310 HAA2US Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Unscrew the 3 Phillips 3.5 mm screws. Use a size 1 Phillips screwdriver.
    • Lift the hardrive.
    • Pull the hard drive out.
Conclusione
Amir Afridi
Membro da: 09/29/16
626 Reputazione
6 Guide realizzate
USF Tampa, Team 4-1, Passmore Fall 2016 Membro di USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,875
