Introduzione
This guide will show how to remove the back cover from the laptop in order to access the parts inside the computer.
This guide will be a pre-requisite guide for replacing the hard drive, and cooling fan.
Cosa ti serve
Slide the battery switch to the unlock symbol, and the battery will pop up.
Remove the battery.
Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
