Introduzione
This guide will provide the necessary steps to remove the screen from the laptop. This guide involves many steps and can be time consuming. Make sure to take your time and follow the instructions completely.
Parti
Turn off the computer.
Disconnect the charging cable from the laptop.
Flip the laptop upside down with the front face down on a flat surface.
Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
Unclip the two white wires connected to the computer chip on the motherboard by pulling the white wire toward you.
Remove the yellow tape securing the black cable that is connected to the motherboard.
Once you have removed the yellow tape, unplug the black cable from its connection on the motherboard.
Altre 6 persone hanno completato questa guida.
