Salta al contenuto principale
Samsung N150 Plus Battery Replacement
  1. Samsung N150 Plus Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
  2. Samsung N150 Plus Battery Replacement: passo 2, immagine 1 di 2 Samsung N150 Plus Battery Replacement: passo 2, immagine 2 di 2
    • Slide the left and right switch to the "unlocked" position.
  3. Samsung N150 Plus Battery Replacement: passo 3, immagine 1 di 2 Samsung N150 Plus Battery Replacement: passo 3, immagine 2 di 2
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,033
