Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide is used as a prerequisite guide to for the removal of the fan, RAM, screen, and keyboard.
  1. Turn off the computer.
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
  2. Slide the left and right switch to the "unlocked" position. Slide the left and right switch to the "unlocked" position.
    • Slide the left and right switch to the "unlocked" position.
  3. While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer. While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
  4. Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
    • Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
  5. Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Apply pressure upwards till the back panel pops off.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard. The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
    • The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 79
