Salta al contenuto principale
Samsung Mythic SGH-a897 Rear Case Replacement
Cosa ti serve
  1. Samsung Mythic SGH-a897 Rear Case Replacement, Battery: passo 1, immagine 1 di 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Rear Case Replacement: passo 2, immagine 1 di 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Rear Case Replacement, Rear Case: passo 3, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Rear Case Replacement: passo 4, immagine 1 di 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
Conclusione
Morgan Yost
Membro da: 04/08/13
46 Reputazione
6 Guide realizzate
Cal Poly, Team 17-1, Regan Spring 2013 Membro di Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 286
