Salta al contenuto principale
Samsung Mythic SGH-a897 Motherboard Replacement
Cosa ti serve
  1. Samsung Mythic SGH-a897 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Motherboard Replacement: passo 2, immagine 1 di 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Motherboard Replacement, Rear Case: passo 3, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Motherboard Replacement: passo 4, immagine 1 di 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Motherboard Replacement, Camera: passo 5, immagine 1 di 2 Samsung Mythic SGH-a897 Motherboard Replacement, Camera: passo 5, immagine 2 di 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Mythic SGH-a897 Motherboard Replacement: passo 7, immagine 2 di 2
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 Motherboard Replacement: passo 9, immagine 1 di 2 Samsung Mythic SGH-a897 Motherboard Replacement: passo 9, immagine 2 di 2
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 Motherboard Replacement: passo 10, immagine 1 di 2 Samsung Mythic SGH-a897 Motherboard Replacement: passo 10, immagine 2 di 2
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 Motherboard Replacement: passo 11, immagine 1 di 1
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 Motherboard Replacement: passo 12, immagine 1 di 2 Samsung Mythic SGH-a897 Motherboard Replacement: passo 12, immagine 2 di 2
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 Motherboard Replacement: passo 13, immagine 1 di 2 Samsung Mythic SGH-a897 Motherboard Replacement: passo 13, immagine 2 di 2
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
Conclusione
Morgan Yost
Membro da: 04/08/13
46 Reputazione
6 Guide realizzate
Cal Poly, Team 17-1, Regan Spring 2013 Membro di Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 462
