Salta al contenuto principale
Samsung Mythic SGH-a897 LCD Replacement
Cosa ti serve
  1. Samsung Mythic SGH-a897 LCD Replacement, Battery: passo 1, immagine 1 di 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 LCD Replacement: passo 2, immagine 1 di 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 LCD Replacement, Rear Case: passo 3, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 LCD Replacement: passo 4, immagine 1 di 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 LCD Replacement, Camera: passo 5, immagine 1 di 2 Samsung Mythic SGH-a897 LCD Replacement, Camera: passo 5, immagine 2 di 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 LCD Replacement, Motherboard: passo 6, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 LCD Replacement: passo 7, immagine 1 di 2 Samsung Mythic SGH-a897 LCD Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 LCD Replacement: passo 8, immagine 1 di 1
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 LCD Replacement: passo 9, immagine 1 di 2 Samsung Mythic SGH-a897 LCD Replacement: passo 9, immagine 2 di 2
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 LCD Replacement: passo 10, immagine 1 di 2 Samsung Mythic SGH-a897 LCD Replacement: passo 10, immagine 2 di 2
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 LCD Replacement: passo 11, immagine 1 di 1
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 LCD Replacement: passo 12, immagine 1 di 2 Samsung Mythic SGH-a897 LCD Replacement: passo 12, immagine 2 di 2
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 LCD Replacement: passo 13, immagine 1 di 2 Samsung Mythic SGH-a897 LCD Replacement: passo 13, immagine 2 di 2
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
  14. Samsung Mythic SGH-a897 LCD Replacement, LCD: passo 14, immagine 1 di 2 Samsung Mythic SGH-a897 LCD Replacement, LCD: passo 14, immagine 2 di 2
    • Hold the phone by the black plastic at the ends and gently bend them down so that the middle of the phone is the highest point. Apply pressure slowly until the grey portion pops off.
  15. Samsung Mythic SGH-a897 LCD Replacement: passo 15, immagine 1 di 3 Samsung Mythic SGH-a897 LCD Replacement: passo 15, immagine 2 di 3 Samsung Mythic SGH-a897 LCD Replacement: passo 15, immagine 3 di 3
    • Insert the tweezers into the hole to wedge them between the LCD and grey plastic.
    • Once under the LCD, slide the tweezers around the three silver edges until the entire display lifts from the grey plastic.
Conclusione
Altre 2 persone hanno completato questa guida.
Morgan Yost
Membro da: 04/08/13
46 Reputazione
6 Guide realizzate
Cal Poly, Team 17-1, Regan Spring 2013 Membro di Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Membri
18 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,367
